VeriStand
Error -2147220616 using Hardware Discovery Wizard
I have a error when searching for devices on my PXIe-8135.
I don't understand where it can com from. NI System Configuration 14.5 is installed on the target.
Is there something missing on the target?
Thanks.
Jean
(4,835 Views)
Hi, Jean. I had the same problem with you. Did your problem be solved? If your problem was solved, please reply me and tell me how you solve it. Thanks!
(4,741 Views)
Hi jay111ln, it seemts that Jean installed TimeSync drivers to his PXIe controller.
You too?
I have heard that installing them causes this trouble.
My suggestion is
- Format your controller
- Install needed software excluding software which are related to TimeSync
Best,
Certified LabVIEW Developer
GCentral
(4,727 Views)
