VeriStand
Error -307606 occurred at System Explorer.lvlib
i have generated a Veristand System definition file from labview using API. I try to open the file but i can't display it in system definition explore for the error that you can see in the picture. My labview version is 2020 and the version of NI Veristand is 2019.
Someone can help me?
(1,717 Views)
You need to have the same version of LabVIEW and VeriStand.  So use VeriStand 2020 or LabVIEW 2019 so they match (LabVIEW 2019 with VeriStand 2019).
(1,704 Views)
