VeriStand
Error 62 when trying to run project on a CRio 9076 with Veristand
 Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2011\Projects\Jason Traub\Jason Traub.nivssdf
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target cRIO.
• Preparing to synchronize with targets...
• Querying the active System Definition file from the targets...
• Unloading System Definition file...
• Connection with target cRIO has been lost.
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2011\Projects\Jason Traub\Jason Traub.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target cRIO...
• Opening FTP session to IP 192.168.1.100...
• Processing Action on Deploy VIs...
• Gathering target dependency files...
• Downloading Jason Traub_cRIO.nivsdat [40 kB] (file 1 of 1)
• Closing FTP session...
• Files successfully deployed to the targets.
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 62 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW:  Serial port overrun error.
LabVIEW:  The system caused the network connection to be aborted.
NI VeriStand:  ??? in Server TCP Interface.lvlib:TCP Send Loop.vi:2->Server TCP Interface.lvlib:TCP Connection Manager.vi:1
(6,397 Views)
Hello Jrad,
Would you mind elaberating on the issue please?
What type of hardware are you using?
When does this error occur?
Can you deploy a simple test system definition?
Are you using the Scan Engine NI VeriStand Custom Device Add-On or are you using the preconfigured FPGA personality?
Wear
Product Support Engineer
(6,366 Views)
Hello Jrad,
Would you mind elaberating on the issue please? Can not load my nivssdf file to my cRIO.
What type of hardware are you using? cRIO-9076
When does this error occur? Seems to tranfer files OK but loses communication via ethernet after that. Cause it to not run.
Can you deploy a simple test system definition? Cannot even deploy a blank project as suggested by tech support.
Are you using the Scan Engine NI VeriStand Custom Device Add-On or are you using the preconfigured FPGA personality? Preconfigured FPGA personality that runs ok in LabVIEW,
 New problem now after trying to look at controller with NIMAX. cRIO status 4.png
Wear
(6,348 Views)
Hello Jrad,
The Veristand and MAX issue are a result of the device not being on the same subnet. Check the IP settings of your PC and the cRIO. This knowledgebase addresses this issue.
Wear
(6,343 Views)
