VeriStand
Error 7 when i deploy a NIVSDF
When i deploy a new nivsdf with the API labiew i get this : L'erreur 7 s'est produite à : Appeler une fonction d'une DLL dans NI VeriStand Engine.lvlib:Run VeriStand Engine (Win).vi->NI VeriStand Server.lvlib:NI VeriStand Server.vi->NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi
The error occurred at 7: Call a function in a DLL NI VeriStand Engine.lvlib: Run VeriStand Engine (Win). Vi-> NI VeriStand Server.lvlib: NI VeriStand Server.vi-> NI VeriStand Gateway . lvlib: VeriStand Server Wrapper.vi
Why ???
(6,059 Views)
Do you have this error for all nivsdf?
Does the error occur for all deployment?
Does the error occur when you deploy without the API LabVIEW ( on Veristand)?
Regards.
Sam
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(6,026 Views)
     Is  NI Veristand running at the background when u deploy the system definition file using labview API?
(6,021 Views)
