06-10-2013 06:02 AM - edited 06-10-2013 06:03 AM
you must have some missing dependencies in your project or your build process is somehow corrupted. The llbs, that you attached has lots of missing vis.
I attached my build llbs and also the project. So you can test this one.
Jiri
CLA, CTA
06-10-2013 07:55 AM
I tested your example. And I came to following finding:
When I compile the custom device, i have to close LabVIEW. If I on system explorer do a new addition of custom device, I have to save and close and after that restart veristand.
So I get a message (look at atttached file), which I have to accept.
After acception, it functions without problems.
Another problem is now, that I could not get CAN-Frame messages. In system explorer I defined another XNET-Session with CAN1. Maybe that's the problem?
Thank you a lot. First step is solved 😉
06-10-2013 08:01 AM
great to hear. that you move on. To reload the llbs, you have to close System Explorer and Project window and open it again!
For the second problem, could you please start a new forum discussion, because the current problem for the post description is solved.
Jiri
CLA, CTA
06-10-2013 08:03 AM
thank you Jiri for your gread help.
Now I am opening new thread for new problem 🙂
YesB
