VeriStand
Error 74, Bug with VI Get fault value
I did a custom control that i use in the Veristand workspace.
When the workspace freeze (I don't no why)  the VI get fault value send a error (74). So i must filter error 74 in my custom control.
I think it is a bug in NI VersiStand 2011...
Michael
(5,913 Views)
I filed CAR# 346665 regarding the error 74 you are receiving.
One question I had was: Does this Workspace freeze you are seeing happen if you don't have that custom control on the screen? How often does the freeze occur?
Jarrod S.
(5,906 Views)
I use VeriStand in local mode to achieve the devellopement custom HMI so I think that's why it freezes.
The problem of freeze is with or without custom HMI.
Michael
(5,890 Views)
