VeriStand
Error when Compiling Simulink model with Veristand
I am trying to compile a simple simulink model to get the process down for eventually using it on a cRIO. Bellow is my error code, model and configuration parameters for the code generation. The issue seems to be with the input and output blocks because I am able to compile a .dll file without them. Does anyone know what this error means or how to fix it?
(2,038 Views)
Accepted by topic author jpeskar
Hi jpeskar,
It seems you're using Simulink 2021a, which is not supported by VeriStand yet. You can find the compatibility table for VeriStand and Simulink versions here https://www.ni.com/en-us/support/documentation/compatibility/17/veristand-version-compatibility.html
(2,001 Views)
Marcelo_I,
You were right. I didn't realize that it 2021a wasn't supported. I installed 2020b and it worked just fine. Thank you for helping.
(1,979 Views)
