VeriStand
Error while deploying to PharLap Target
I have a problem deploying to the PharLap Target that I´m using for the testing of a custom device. A pop up windows appear with the following problem:
NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi >> Waveform Services.lvlib:Clear Active Streams.vi >> Server TCP Interface.lvlib:TCP Send Target System Command.vi:5680001 >> Server TCP Interface.lvlib:TCP Send Target Message.vi:890001
<append>=========================
NI VeriStand: HiLTarget
Then in the deploying window:
• Start Date: 17.06.2019 16:13
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2018\Projects\Untitled 6\Untitled 6.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target HiLTarget.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target HiLTarget...
• Opening WebDAV session to IP 192.168.2.188...
• Processing Action on Deploy VIs...
• Gathering target dependency files...
• Downloading Untitled 6.nivssdf [43 kB] (file 1 of 4)
• Downloading Untitled 6_HiLTarget.nivsdat [2 kB] (file 2 of 4)
• Downloading CalibrationData.nivscal [0 kB] (file 3 of 4)
• Downloading Untitled 6_HiLTarget.nivsparam [0 kB] (file 4 of 4)
• Closing WebDAV session...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -124201 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
LabVIEW: (Hex 0xFFFE1AD7) Unbekannter interner Fehler.
• Stopping TCP loops.
Waiting for TCP loops to shut down...
• TCP loops shut down successfully.
• Unloading System Definition file...
• Connection with target HiLTarget has been lost.
This is not my real project. This is just a blank project and I still get the same error.
I´m using LabVIEW 2018 + VeriStand 2018. and the target uses NI Real-Time Phar Lap ETS 13.1. I reinstalled twice the VeriStanf Enging to no avail. Also, I´m able to deploy and use software from LabVIEW to the target.
It´s worth menting that I can successfully deploy both the blank and my real projects in my local PC. (WIN10).
Thanks!
(3,277 Views)
If you get this error deploying a blank SDF to the target, then something is probably wrong with the software stack on the target or the problem is with the network. You said you reinstalled the VeriStand engine, but I'd recommend completely formatting the PXI controller and then reinstall software.
Also, do you have any firewall or AV software that might be blocking the deployment? It looks like the error is being thrown during the WebDAV session that is copying files over to the target.
-Jordan
(3,241 Views)
Thanks for the reply.
The thing is that everyone else here can deploy, is only my terminal the one that cant. Ill Check out the firewall tomorrow. Thanks!
(3,232 Views)
