VeriStand
Errors when subsystems are used
When I use subsystems in Simulink, it generates naturally a "/" to indicate that there is something beneath the subsystem but this causes the error I attached to this question. When I eliminate the subsystems and take the inside out then it gives the same error with the title of the model. Note: I commented out the mentioned subsystems and got the message saying only: "errors occured" and nothing specific. How can I solve this issue?
(2,577 Views)
have you tried not to use the "/" at the end of the name like the error states out?
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(2,533 Views)
