VeriStand
Ethernet communcation in VeriStand project : required hardware and implementation.
Hi National Instruments,
I would like to use Ethernet communication in a VeriStand project and I would like to know if I can use the Ethernet ports of my controller (PXI8840) or if I need to use a separate PXI Ethernet interface module.
Also is it required that I use a custom device to perform Ethernet communication or can I do it directly in VeriStand, in a simillar way to CAN communication for instance ?
(3,006 Views)
My current answer :
1. I don't need to use a separate PXI Ethernet Interface module because my controller has two Ethernet ports. Such a device is useful only for Ethernet projects that require more flexibility, in terms of subnets.
2. It is impossible to do Ethernet in VeriStand without using a LabView custom device.
Sources:
- https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9ULSA0
- https://forums.ni.com/t5/NI-VeriStand-Add-Ons-Documents/NI-VeriStand-Add-On-Ethernet-IP-Custom-Devic...
(2,991 Views)
