VeriStand
Failed to compile the simulink model due to the NiBusLib.tlc
I tried to compile the simulink model of MATLAB 2016a to a dll file in NI Veristand 2017 MIT by VS2010SP. However, Error appeared as follows: Error: File: C:\Veristand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 1063 Column: 49 Unable to find Members within the CGType scope. Error: File: C:\VeriStand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 106 Column: 57 The left-hand side of a . operator must be a valid scope identifier. Error: File: C:\VeriStand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 106 Column: 57 The argument for an [] operation must be a repeated scope symbol, a vector, or a matrix Error: File: C:\VeriStand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 110 Column: 54 The left-hand side of a . operator must be a valid scope identifier. Error: File: C:\VeriStand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 113 Column: 17 The left-hand side of a . operator must be a valid scope identifier. How this happened? Could someone help me to solve these problems?
(1,737 Views)
What is your OS?
Maybe it will better to share a screenshot of the error too.
(1,667 Views)
