VeriStand
Fault channel & Stimulis profil
When i use the stimulis profil API in LabvVIEW for launch a nivseq who fault a channel when the channel is mapped to a other channel the fault is not applicated.
Why ?
(6,204 Views)
Which version of VeriStand are you using? 2011 or 2011 SP1?
Jarrod S.
(6,198 Views)
Veristand 2011
(6,186 Views)
Accepted by topic author Lunik
There is a bug in VeriStand that was fixed in VeriStand 2011 SP1, where faults applied from a sequence would not take affect unless some other channel had already been faulted through the Channel Fault Manager tool.
If you can't upgrade to 2011 SP1, then as a workaround you can create a dummy user channel in your system definition and leave it faulted from the Channel Fault Manager workspace tool for the duration of your sequence execution.
Jarrod S.
(6,176 Views)
