VeriStand
Get Sequence Return Values - NotDeployedException
I start in TestStand via .NET a stimulus profile with a "Realtime-Sequence Group"-Step that include three sequence calls. (Sequences execute in parallel). After execution I want to get the return values of these sequences for reporting purposes in TestStand.
To get the return values I use in TestStand the "Run VI Asynchronously" Step with the attached VI three times.
Sometimes I get an empty Array from the "Get All Deployed Stimulus Profile Sessions"-VI and an NotDeployedException.
Why does this happen?
For starting the stimulus profile I use the ExecuteAsync function (RealTimeSequenceDefinitionApi, Root Class: StimulusProfileDefinitionApi.StimulusProfile) in TestStand.
Is it necessary to deploy the stimulus profile additionally? How can I do this?
I only found a function to create a stimulus profile with the .NET API but no method to deploy an existing stimulus profile where I can name the filepath to the stimulus profile.
Any ideas how to solve this issue?
Message 1 of 1
(2,939 Views)
