VeriStand
How can I capture all CAN traffic in VS2009?
I am debugging CAN communications in VS2009 having the XNET add-on. Frames send fine. Incoming frames look fine monitored externally, but I get value 0 for all channels from incoming frames,
To troubleshoot the issue I would like to see all frames on the bus as VS sees them. I thought that there was an add-on for VS2009 that added this functionality, but it seems to have disappeared now that the functionality has been rolled into VS2010. Could someone please make the add-on available to me? ...or correct my erroneous memory and offer a suggestion on troubleshooting my issue. - thanks
(7,150 Views)
As of my knowledge, the XNET add-on custom device for NIVeriStand 09 neither has the capability of raw frame data logging nor to stream data to the bus monitor.
If you are talking about a generic way to log data, check out the embedded data logging add-on:
http://zone.ni.com/devzone/cda/epd/p/id/6240
If you need raw frame data logging I suggest to modify the source of the XNET custom device. The custom device is open source and fairly simple to modify.
Tom
(7,147 Views)
Thank you. This looks like the add-on I was thinking of.
It didn't show up in the searches I tried. Even now "search" does not find "embedded data logger". ¿outside the search engine's scope?
Unfortunately I have to work around some things that have been resolved in VS2010, for a little while longer. It would be helpful to have access to the older documentation (prior to VS2010 release). Is there a link to the "old" add-ons page?
(7,142 Views)
I have 'jinged' they way I got the link:
http://www.screencast.com/users/ThSa/folders/Jing/media/84491e24-5ad0-414d-8478-ff68a2f3a865
Whenever you visit a custom device page, there should be multiple downloads available for custom devices which exist in multiple versions of NI VeriStand.
(7,139 Views)
There it was, right there in the list I had looked through. Duh. I'm still perplexed by the lack of the EXACT TITLE of the add-on not coming up in the search. I thought the older add-ons had been removed. My mistake. Thank you for your help. BTW, cool way to "show".
Thanks again.
(7,135 Views)
I think it's not your lucky day today 🙂
I just checked out the search engine on ni.com and it works perfectly fine.
Another jing:
http://www.screencast.com/users/ThSa/folders/Jing/media/3ee64cfb-15c7-422c-8988-2dd82f40228f
(7,131 Views)
