VeriStand
How do I make an alarm in VeriStand that checks for specific value?
I need the alarm to be triggered when the channel value is 0x2C and only 0x2C.
(5,879 Views)
Accepted by topic author jaime_c
Create a Calculated Channel and select "Conditional" from the dropdown list.  Use the "=" condition to compare your channel to a constant value.  The calculated channel will be 0 when the condition is false, and 1 when it is true.  You can then create an alarm based on the calculated channel you created.
Hope that helps!
(5,865 Views)
