VeriStand
How set real time model parameters?
Hi.
Environment : veristand 2013 sp1
I have a model with several parameters which turns on a real time target at 1khz
I want to change parameters value and i would like to these are applied in the same cycle or with one cycle late maximum.
I remark that when i am using model parameter manager, the application delay are not determinist.
But my application requires determinist cycle and the sequences must be repeatable.
Do you know how to pass model parameters directly in the HP loop to apply them in real time?
For information I have tested the macro player which gives me the same results and I try to change parameters into channels. It works but unfortunately I don't keep this solution.
Best regards.
R.kaszubiak
(3,744 Views)
Hi R.kaszubiak,
Why is the solution with the macro player not acceptable for you ?
(3,714 Views)
