VeriStand
How to solve Error C2198 'NIRT_GetValueByDataType' : too few arguments for call
I am receiving the following error message several times during mdl compilation:
### NI VeriStand 2010f1 Modifying bleed_real_time_iron_bird_nolinks_data.c file
bleed_real_time_iron_bird_nolinks.c(16858) : error C2039: 'Integrator_CSTATE_ma' : is not a member of 'ContinuousStates_bleed_real_time_iron_bird_nolinks'
        c:\workdir\models\bleed_revd\bleed_real_time_iron_bird_nolinks_niveristand_rtw\bleed_real_time_iron_bird_nolinks.h(1277) : see declaration of 'ContinuousStates_bleed_real_time_iron_bird_nolinks'
bleed_real_time_iron_bird_nolinks.c(16858) : error C2198: 'NIRT_GetValueByDataType' : too few arguments for call
How can I repair them?
Cheers,
CHCastro
(7,318 Views)
Accepted by topic author ClaudioH
The problems disappears when we unset the block option: "Treat as Atomic Unit".
One important note: this problem does not occurs when using other tlc than NI Veristand.
Cheers
CHCastro
(7,287 Views)
