VeriStand
I am having issues with subVi's after using the custom device template
I used the custom device template to start my custom device and i have had success in deploying until I started making more complicated subVi's.   I currently am trying to convert FPGA low and high ticks to duty cycle, but for some reason when i add it to the RT Driver VI 'Read Data From HW', it seems to cause a time out.... any thoughts? Is a loop okay? I have added a time delay but am still having issues. It is an inline device, so i am suspicious about it hogging resources, but am not sure.
 THe attached images are meant to be read like this:
1. The ReadDataFromHW case of the RT Driver
2. This is the subVi that calls ToDutyCycle SIMStimPWMSubVI
3. ShiftRegister.PNG is the inside of the SubVI.
(4,845 Views)
Accepted by topic author wegunterjrASI
As a roboticist I celebrate early and often (usually through a failure or two...), but it seems that the answer was to basically convert the While Loop to a for loop with a count of 1, and then remove extra elements to make sure each shift register has only one, and then right click on the shift registers and convert to Feedback Node....
I was able to deploy to VeriStand as a Custom Device and it runs and calculates the Duty Cycle without any issues. WOOHOO!!! Where is that celebrate button!
(4,794 Views)
Thanks for posting that you were able to resolve your issue.
Please see attached for celebration.
Thomas C.
FlexRIO Product Support Engineer
(4,744 Views)
