VeriStand
IRQ timeout error while executing the custom personality fpga in veristand
I have gone through the below link and created a custom fpga code to write analog output and digital output through NI 9269 and NI 9472 card respectively.
NI Veristand add on - fpga configuration editor.
https://decibel.ni.com/content/docs/DOC-35499
i was able to import the .fpgaconfig file in veristand system definition window.
When i execute the code, i am getting IRQ timeout error.
Could any one help me how do i debug this error?
i am interested to see how the veristand host code is executing it.
(4,740 Views)
Have you tried to simplify the FPGA code? If the issue is related to the VCE, you should post there :
https://decibel.ni.com/content/message/67188#67188
The developers of this tool will answer you.
Posting the error message or the FPGA code will also help us 🙂
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(4,692 Views)
Most probably number of items in FIFO from FPGA will not match the number of items (packets) in the XML.
CLA, CTA
(4,682 Views)
