VeriStand
Import simulation model
I have a PXI and Crio and I would like to do simulation Hardware in the loop.
For the model, I have made a simulation model with Simulation X and I compile it with special Veristand modul. This modul convert my model in dll.
I execute my dll model with my pharlap target (PXI) and i have this error :
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307703 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: Le modèle spécifié n'est pas compatible avec NI VeriStand. Si vous essayez de déployer le modèle sur une cible RT, lancez l'outil Console Viewer pour afficher la sortie console de la cible, qui inclut des informations sur la source de l'erreur.
NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> Model Execution.lvlib:Initialize Model Loop Data.vi >> Model Execution.lvlib:Initialize Models.vi >> SIT Model API.lvlib:Initialize Model.vi >> SIT Model API.lvlib:Load Model DLL.vi
<append>=========================
NI VeriStand: Failed to load C:\ni-rt\NIVeriStand\Models\XXXX.dll
How execute a dll model with Veristand ? Is it possible ?
Emma
(2,434 Views)
Hello Emma,
This error could be associated to a multiple sources.
First, you can check the compatibility of your software with this document NI VeriStand Version Compatibility
If everything is ok, Could you create a simple model with an addition (for example) and test with it ?
Eloise
NI France
(2,299 Views)
