VeriStand
Importing 3rd Party ECAT Slave in Veristand 2017 fails with unknown error
I am trying to import my 3rd party Ethercat slaves into Veristand 2017, but xml files from different vendors all fail with the same error message: "The software cannot import the device profile. Refer to the NI-Industrial Communications for EtherCAT Help..."
I installed the Network Variable Engine and there should be no firewall. Deploying a project works well, also the fpga in the 9144 chassis are deploying fine. Any ideas?
Thanks in advance!
Message 1 of 11
(5,258 Views)
Update, what I tried so far:
- New Project with no other components, doesn't import.
- Tried to import the files mentioned in this post (Beckhoff): https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/3rd-party-EtherCAT-slave-Importing-XML-Devi...
- I checked for whitespace Start/End in the Name Tags mentioned here: http://digital.ni.com/public.nsf/websearch/2989174EA40C087786257A9B0039BFD4?opendocument&Submitted&&...
Still, no success
Message 2 of 11
(5,211 Views)
Same in Veristand 2016
Message 3 of 11
(5,183 Views)
Are you using Win 10? If so, have you tried the following KB?
http://digital.ni.com/public.nsf/allkb/2606F688B3CF3FD186258091000BC6A8
Message 4 of 11
(5,179 Views)
Thanks for the suggestion!
I have tried adding the xml files to the path suggested in the KB, unfortunately with no success.
I also copied the files to the "path to LabView"\resource\Framework\Providers\indcomecat\DD, no success.
I'm using Win7, the error appears already while importing the xml. Maybe the problem is also that I'm using Veristand, this solution was reported for LabView.
Message 5 of 11
(5,177 Views)
OK.
I see that you are able to use NI 9144 correctly. So I think the ESI of NI 9144 must work correctly. Can you find where is the ESI of NI 9144 on your PC? You can use Everything software (https://www.voidtools.com/) to find NI-9144slots.xml. Then open the location and check if your ESIs are already there. If not, copy all the necessary ESIs to the directory and close all NI software. Retry.
Message 6 of 11
(5,175 Views)
I copied the files to these three locations:
Unfortunately without any success. Thanks for the tip with the tool btw., looks quite handy.
Message 7 of 11
(5,172 Views)
I see. I would recommend you to contact National Instruments about this issue.  Contact your local applications engineer so we can take a look at this further, as they can devote resources towards this issue.
Message 8 of 11
(5,159 Views)
Thanks for your help, I have done that. I will sum it up here for future reference as soon as it's resolved.
Message 9 of 11
(5,153 Views)
Accepted by topic author raphael.wittwer
I managed to add the slaves finally. Instead of importing the xml with "Manage 3rd-Party ECAT Slaves" I had to select "Auto-Detect Modules". Wheter this works only because I copied the xml to the LabView path remains unclear, as soon as I have further insight I'll share it here.
Message 10 of 11
(5,129 Views)
