VeriStand
Is there anyone who had problem adding model?
Hi. I have some problem with adding models to veristand.
I used veristand 2021 R3 and including model generation tool kit, all of program was installed.
However when I added .dll type model to the veristand error code -1, -307703 occured.
So i tried again with .vsmodel but this time the veristand doesn't think it's a valid file.
I am totally confused and have no idea what to do.
can somebody please help me?
(574 Views)
Error -1 or Error -307703 When Adding vsmodel to VeriStand
Only add the vsmodel file in the Mapping Diagram but not in the System Explorer.
https://tmesystems.net/
(497 Views)
Well after I saw yout comment I tried it. but it still dont work.
So I guess that wasn't the answer
(492 Views)
Are you building the model in LabVIEW?  What system are you compiling the model to, Windows, Linux RT? This will determine what type of file is built.
Have you had errors building your model or just adding it to VeriStand?
(473 Views)
No. The model was builted by matlab. I'm not sure about exact system but It was window for sure.
and the error occured  just simply just adding to veristand
(449 Views)
