VeriStand
Logging datas from Veristand to CRIO FTP Server
is ther any way to log datas from Veristand directly to cRIO ftp server?
(1,363 Views)
FTP Server lists all the files available on the cRIO hard drive. Any options in Data Logging Options that write files to Target will save the files to the cRIO hard drive.
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(1,358 Views)
