VeriStand
Managing undeploy command
I have a use case where I need to have a control on the UNDEPLOY command. The real time application (model or custom device) should be able to forbid, cancel or at least delay consequently the UNDEPLOYEMENT of the target, regarding to the current state of the process. The ideal solution would be to have a sort of hook in the command at the PC side, but any good alternative can be considered.
Message 1 of 1
(538 Views)
