VeriStand
Mapping error when Channel name include comma
Hello
When I import & export mapping in Mapping Diagram, Error come out if channel name include "Comma" like below.
If I use Bus(Vector) data type at Simulink model, it automatically recognized into set of scalar datas as like below.  (it automatically include "comma" and I can not change name)
<outportname>(1,0)
<outportname>(1,1)
<outportname>(1,2)
What I only can do is make all import/outport block as scalar data and not use bus data type.
but if i have many import/outport blocks, it will be complicated.
Dose anyone have other workaround for it?
any advice would be greatly appreciated.
thanks regard
(1,544 Views)
Thanks for the feedback - I agree that this is a frustrating problem. This is in fact a known issue and I anticipate that it will be addressed in an upcoming release of VeriStand.
A channel name does not support a comma in VeriStand, so making the import/outport block as scalar data seems the workaround for your case.
(1,496 Views)
