10-10-2013 10:37 AM
Hi
I am new to Veristand and Labview and I was wondering if there's the possibility to do the following:
I would like to measure the period of a sinewave I capture from the analog input of my DAQ (PXIe-6363). Apart from that i would also like to measure the peak to peak value (Vpp) of that sinewave.
I hope you can help me out.
Thanks.
Solved! Go to Solution.
10-10-2013 10:42 AM
Of course its possible but i think its not possible natively. To do this, you have to develop your own Custom Device.
Bye,
CFOE
10-10-2013 10:52 AM - edited 10-10-2013 10:53 AM
You might look into using the Peak and Valley calculated channel type available in the System Definition. This will help you calculate the peak to peak value. It doesn't give you the period of the sinewave, but you might be able to detect that with other calculated channels by monitoring when the value changes on the peak channel.
Also, you could perhaps use the FFT graph in the Workspace to get the frequency of the sinewave.
10-11-2013 04:26 AM - edited 10-11-2013 04:26 AM
Hello
I have used the Peak and Valley calculated channel to calculate the peak to peak value and it works fine at low frequencies, but when I increase the frequency, the peak to peak value decreases significantly due to valley and peak values decrease too. How can be this solved?
Thanks.
10-14-2013 10:02 AM
You could just make a veristand model. Develop everything as a labview VI, have the input to the VI be the analog signal, and the ouput be your peak to peak and frequency.
10-14-2013 01:44 PM
In order to get a good characterization of the period wave, you probably need to be sampling about 10x faster than its frequency. What are the frequencies of the Primary Control Loop and the signal you are measuring?
10-14-2013 06:34 PM
if the sinewave is of significantly higher frequency than the primary control loop can run... The best way to do this would be to put the DAQ device into waveform input mode and use a custom device to read the waveform and perform analysis.
an example is here: requires some labview skills
<LabVIEW>\examples\NI VeriStand\Custom Devices\waveform analysis
