VeriStand
Measurement and data export
I want to make a measurement with my PXI-e system, record the history and then export it.
Is this possible in VeriStand, if so how?
best regards,
Ache
(2,727 Views)
Accepted by topic author ache
Hi Ache,
if you have a PXIe-Device that works on DAQmx (e.g. PXIe-63xx, PXI-62xx ...) this should work out of the box. See this Help Article for how to log data from your Veristand System:
http://zone.ni.com/reference/en-XX/help/372846M-01/veristand/vs_logging_options/
If you are using a different device (e.g. a NI-Scope, NI-DMM ...) you would need to use a Custom Device for the Device-Type you are using.
I hope this helps!
Cheers,
Jan Göbel
Staff TSE
(2,694 Views)
