VeriStand
Missing ASAM.XIL.Implementation.TestbenchFactory.Testbench
Hi all,
I am trying to interface to VeriStand through the ASAM XIL API. I am using examples from C# Walkthrough: Using the Model Access Port to Read and Write Channel Values
However, when compiling, it cannot find the ASAM.XIL.Implementation.TestbenchFactory.Testbench dependency and I cannot find it anywhere in the VeriStand installation/user folders.
I am using Veristand 2016 downloaded from
http://www.ni.com/gate/gb/GB_EVALVERISTAND/US
Anyone having the same issue? How to resolve it?
(7,866 Views)
Accepted by topic author dagobert
Dagobert,
You can add a reference to the ASAM.XIL.Implementation.TestbenchFactory.Testbench in the C# environment that you are working with. In Visual Studio, in the Solution Explorer there is a reference tab and you can right click and add references.
You can browse to the following location to get the “using ASAM.XIL.Implementation.TestbenchFactory.Testbench;” specifically.
The file path should be located here: C:\Windows\Microsoft.NET\assembly\GAC_MSIL\ASAM.XIL.Implementation.TestbenchFactory.
Please let me know if this works for you.
Sarina
Applications Engineering
(7,808 Views)
following dependency for NIVS 2016:
c:\Windows\Microsoft.NET\assembly\GAC_MSIL\ASAM.XIL.Interfaces\v4.0_2.0.1.0__bf471dff114ae984\ASAM.XIL.Interfaces.dll
c:\Windows\Microsoft.NET\assembly\GAC_MSIL\ASAM.XIL.Implementation.TestbenchFactory\v4.0_2.0.1.0__fc9d65855b27d387\ASAM.XIL.Implementation.TestbenchFactory.dll
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\ASAM.XIL.Implementation.Testbench\v4.0_2.0.1.0__a258c402a414cddb\ASAM.XIL.Implementation.Testbench.dll
~Jiri
CLA, CTA, CLED
(7,794 Views)
Exactly what I was looking for! Thank you!
(7,786 Views)
