VeriStand
Model Build error
HI,
Am trying to generate a dll from a simulink model. But when i tried to build it generates a error.Please suggest the change to be made
-SID
(5,653 Views)
Accepted by topic author SID-SysEng
Looks like it's not able to find nmake.exe.  Verify that you have a valid compiler installed on your machine (see the NI VeriStand readme for supported versions.  You should be able to download a free Express edition from Microsoft's website).  Run "mex -setup" to configure your compiler settings in ML.
(5,647 Views)
