VeriStand
NI 9361 Counter Input and NI XNET 9862 with cRIO in VeriStand
How to utilize NI XNET 9862 & NI 9361 Counter Input with cRIO 9033 in VeriStand.
1. I got information about utilizing NI XNET 9862 module in cRIO in post
http://forums.ni.com/t5/NI-VeriStand-Add-Ons-Documents/NI-VeriStand-Add-On-Scan-Engine-and-EtherCAT/...
2. To read/acquire through NI 9361 Counter input we need to create FPGA Personality for VeriStand as this module will not support Scan mode.
My queries on above scenarios are :-
Above in point 1 using XNET module needs empty bit file and I need to add that bit file in CAN port configuration under XNET support. For utilizing Counter input module I need to create FPGA Personality bit file and then use in FPGA section of Hardware in VeriStand.
After doing both the activity will VeriStand and NI platform be able to run both the configuration at same time?
Kindly suggest me to get data from NI 9361 Counter Input and NI XNET 9862  in VeriStand using cRIO.
Message 1 of 1
(2,910 Views)
