VeriStand
NI VeriStand 2013sp1 use in PXI8115 RT system
1)I tried to deploy the example of sinewave delay to PXI 8115 RT system,but the deployment failed with this error message,What causes the error, and how can I solve the problem?
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 1003 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW: 无法执行该VI。造成该错误的原因可能是VI断开或者子VI无法定位。选择文件>>打开可打开VI并确保可以运行该VI。
NI VeriStand: Launch Asynchronous VI by Name.vi->Model Execution.lvlib:Launch Model Loops.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi中的打开VI引用<APPEND>
Model Execution.lvlib:Model Execution Loop.vi
2)I have a error when searching for devices on my PXI-8115, NI System Configuration 14.0 is installed on the target.
Message 1 of 1
(3,718 Views)
