VeriStand
NI VeriStand Deployment Error Code -307673
I am having a strange problem with VeriStand for past couple of days. Please can someone help?
I have Veristand 2017 running on Windows 7. When I deploy my VeriStand FPGA project to the target (cRIO 9035), I get an error that says that another VeriStand gateway is already connected to my Execution host. This is strange because my PC is the only one connected to the cRIO and I am not connected to any network (both PC and cRIO are directly connected). I have been able to run this same VeriStand project on the cRIO before without any errors until last week.
Here is what I have tried so far:
I have restarted both the PC and cRIO but still the error persists.
I can run the FPGA VI on the target from LabVIEW without any errors.
I have reinstalled VeriStand engine on the cRIO but still getting the error.
I can run another VeriStand project on Windows (local host) without getting any errors.
I have attached the Deploy Status log.
Thank you for any troubleshooting advice!
RagMan
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307673 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: Another VeriStand Gateway already is connected to the execution host. Only one VeriStand Gateway can be connected to an execution host at a time.
NI VeriStand: NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi
<append>=========================
NI VeriStand: The target Controller is already connected to the VeriStand Gateway running on host LE911704.local.
Message 1 of 1
(2,628 Views)
