VeriStand
NI VeriStand - 'Set channel values by block data reference.vi'
I make an asyncronous custom device application on a VS proj and
I would like to change programmately the value of the channels output list inside RT driver.
I find the function 'Set channel values by block data reference.vi' but it sets the values of an inline custom device channels..
I wonder if exist the same function to asyncronous custom device or if there is the possibility to do that in other way?
thanks,
best regards,
Marco
(5,151 Views)
Marco,
I've had the same need several times before. I would recommend an inline custom device that launches an asynchronous engine. Then from your inline device you can use the block writes and communicate the data to that loop from the engine using something like a single element queue.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(4,985 Views)
