VeriStand
NI VeriStand error -307850
I'm using Engine Demo project with VeriStand 2014. I want to execute it in cRIO-9033, so I've included in the system definition file an RT Controller selecting VxWorks for the OS, and using the same IP address displayed for the CompactRIO system in MAX. When I deploy the System Definition File, VeriStand Gateway encountered an error. The ethernet cable is connected and it's running because it's answering to a ping command.
I've read I need to install NI VeriStand Engine on the real-time target (cRIO-9033) but when I select Custom Software Installation from MAX in Remote Systems->cRIO9033->Software->Add/Remove Software, NI VeriStand Engine is not inside possible features to install. Could be this the problem?How can be resolved?
Thank you in advance
(4,968 Views)
The 9033 runs Linux
http://digital.ni.com/public.nsf/allkb/35F1FD98520D6E0E8625783A005AF557
Ni veristand does not yet support that operating system.
Stephen B
(4,938 Views)
