VeriStand
NI Veristand: Hardware Discovery Wizard
Hi All,
I have just installed NI Veristand 2012 to my NI-PXIe8135.
I have LabVIEW 2012. It shall be compatible and no issues.
When i try to use Hardware Discovery Wizard, i have got error message as in attachment.
Could someone please explain me what is it?
Thank you,
Rajamodol
(6,419 Views)
Hi Rajamodol,
i am pretty sure, that you're using the wrong DAQmx Version. You need DAQmx 9.6 to get this working. I had the same error with 9.5.5.
Please make an update.
Cheers,
Philip
(6,392 Views)
This issue has been reported to engineering for further investigation (CAR# 386954). We have reproduced it internally, but only intermittently and rarely. Does this reproduce every time for you? Can you try launching the Hardware Discovery Wizard a few times, possibly from a few different nodes in the system definition (Target, Chassis, DAQ, etc.)?
I would guess that if you try a couple times, the Hardware Discovery Wizard will launch successfully, but please let us know.
Jarrod S.
(6,378 Views)
Hi Phips..
Thanks for your reply.
I have NI-DAQmx 9.6.1 on host and RT-Target.
@Jarrot_S
Yes, after re-open Veristand for 1-2 times, it works. I don't know why. I hope this issue could be resolved soon for Veristand 2012.
Rajamodol
(6,363 Views)
Hi there,
Had the same error the first 2 times I wanted to try that feature. After rebooting/relaunching VeriStand, it worked, and never got the error again so far. Looks like it's related to NI-System Configuration settings...
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(6,342 Views)
