VeriStand
NI - Veristand not responding to model made on Labview
I have made a PWM model using Labview for Veristand. I am using Veristand on a RT target (PXI).
Now when i configure my work space it is not actually responding as it should. I guess i have done something wrong with this model. I am attaching the VI of model with this. Can someone please check and tell why veristand is not responding to this model
(2,313 Views)
Since your model has loops, it could pass only final data to the terminals.
  1. Try alternate method to develop model for PWM using Control design simulation or Simulink. (Don't use loop)
  2. You could use Stimulus profile editor to generate signals with Variable replay function.
(2,213 Views)
