VeriStand
Need to sort channels and expand path
I have well over a hundred signals I need to datalog but I need them in a certain order.  How can I sort the order and I also need to expand the scrren to see the path.
See attached.
(6,634 Views)
To add the features you want to the custom device you need to add a horizontal scroll bar and enable dragging (see screenshot below) in the "Channel group page.vi" (it is part of the Embedded Data Logger source code)
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
(6,615 Views)
Wher can I find the Embedded Data Logger in NIVS 2011?
(6,581 Views)
The source code for the Embedded Data Logger custom device is not publicly available. You can create a Service Request and one of our Application Engineers will help you.
Sev K.
(6,571 Views)
Attached are suggestions I think would be helpful to a user of the Veristand Embedded Data Logger.
-The ability to horizontally scroll.
-Grab and rearrange the channel order
-Store channels to a file
-Load channels to a file
-Dennis
(6,479 Views)
Hi Dennis,
Thanks for including the modified version of the code with the additional features. I've forwarded your suggestions to the Veristand R&D group.
Sev K.
(6,461 Views)
