VeriStand
Not able to retrieve the log from Bus monitor NI MAX
I am not able to retrieve the log from Bus Monitor using NI MAX.
to save the log file i am not able to find the browser option in logging window. check in attached snapshot.
Please help to me to take the CAN logs form Bus Monitor.
(2,348 Views)
There is no image attached. Please attach your snapshot.
https://tmesystems.net/
(2,313 Views)
(2,306 Views)
I guess your XNET device is on the remote RT target. The log file is generated on the RT target. You need to transfer the file from the RT target. Tools Available for File Transfer/Access on NI Linux Real-Time Targets
I don't remember the exact path but it should be somewhere around /c/ni-rt/xnet
(2,301 Views)
The directory of this file is  /home/lvuser/[File Name]
(1,181 Views)
