VeriStand
PWM Signal from PXI-7853R to Veristand
Hello dear Members,
I am trying currently to receive PWM signals from my PXI-7853R which is connected to an ECU. The ECU is actually generating the PWM Signal. Therefore I used a breakeout box from NI to connect the pins/ports. Now I connected the breakeout box with according cable to my PXI-7853R.
So now the issue is, I can measure with the oscilloscope a PWM signal but I cant receive that signal in my Veristand program vi.
Thanks for any help an suggestions.
(3,595 Views)
Hello Study2019,
Can you describe how you measure the PWM signals in Veristand?  With a custom device or a FPGA personality?
Maybe there's something wrong with your code?
Thanks!
(2,187 Views)
Hello Study2019,
Are you sure you used proper cables and connector block?
Have you tried to acquire the PWM using NI MAX?
__________________________________________
The best way to thank, is to give KUDOS
(2,053 Views)
