VeriStand
Problem including LabVIEW custom device
Hello together,
i want to include the custom device attached, which is given as a example from LabVIEW. After importing it into the correct folder, i could find it as custom device in VeriStand. As soon as i want to add it, i recieve a "error 7" message as it is explained here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NBYSA2&l=de-DE
But the solution explained dont help in my case.
Does anyone know, how to fix my problem?
(I use a PXI System with PharLap OS)
(1,898 Views)
Accepted by topic author mihamm
Hey,
works fine to me. Maybe you skipped the step in which you need to compile the LLBs from the LabVIEW project? Also don't forget to update the destination folders for both Configuration and Engine build specifications in order to point to the right NI VeriStand folder (if you are using other NIVS version then 2015).
Step 1 - Fix destination paths:
Step 2 - Build all build specifications:
Step 3 - Restart NIVS (if opened) and play with your Custom Device...
CLA, CTA, CLED
(1,842 Views)
Thank you for your answer,
now it works. The Problem was, i did not built al...
(1,821 Views)
