VeriStand
Programmatically get VeriStand device channels
Is there a way to automatically populate a document with all the device channels in VeriStand?  Basically I want to be able to run this program and generate an alias channel address template for a given system so that a test engineer can just populate the names they want to use for aliases.  I'm talking about getting the addresses that look like this:  Targets/Controller/Chassis1/Hardware... or Custom Devices... etc.
I know that if I use a .NET constructor I can access of all this for a given system def. file by using invoke nodes and property nodes.  The problem is that I can't find a way to populate a list with everything in the SDF, if I know exactly what the SDF looks like I can do it no problem.  I'd like to find a way to be able detect what is there and then populate a list.
Does anyone know how to do this? I was thinking that maybe there is a recursive way of programming it and checking if something is there for not, but I'm honestly not an experienced enough programmer to know how to set up a good recursive method for this.
Alternatively, I could possibly get way to do this (minus custom devices) by pulling the same information from MAX about what is the PXI chassis.
Thanks in advance for the help.
(7,366 Views)
Try this out. Open Project Explorer in VeriStand. Right click on the Workspace item in the tree and select Export Channel Resource. A dialog pops up where you can select which channels to export.
When you click OK a tab-delimited file is generated with the channel list and some basic information about the channel, such as whether it can be written to. For example:
Channel Name Alias Channel Path Type Description Units Readable Writable Faultable Scalable
DI0 Targets/Controller/Hardware/Chassis/DAQ/Dev1/Digital Input/port0/DI0 Digital pin 0 on port 0 TRUE FALSE TRUE FALSE
DI1 Targets/Controller/Hardware/Chassis/DAQ/Dev1/Digital Input/port0/DI1 Digital pin 1 on port 0 TRUE FALSE TRUE FALSE
Jarrod S.
(7,355 Views)
I will look into that when I get to my work station later today.  Do you know if there is anyway to access this exporter through LabVIEW and pull them into a program automattically?  We are looking for ways to reduce the chance of manual error.  I'd like to pull all of the resources from VeriStand just as the exporter does, allow a user to enter in names for the channels and have it automatically generate an alias list for the user.
(7,347 Views)
there is a way to do this 🙂 Its currently being developed....stay tuned
Certified LabVIEW Architect
(7,248 Views)
That's good to hear.  It will be very helpful to have that feature since different test benches will eventually have different names/cards/etc. as the initial software is used more and more.  Do you have an idea when this is going to be released?
(7,232 Views)
Unfortunately I do not.  But I would imagine if my company sees there is a real desire for it in the VeriStand community, that will push up production.
(7,230 Views)
