VeriStand
Pulse Measurement Channel Properties (CI)
I plan to use this type of channel to measure the value of a PWM signal (pulse-width and Frequency).
Does Veristand use semi-period to mesure these values ?
Is ther some limitation in this mesurements ? min/max frequency and pulse-width of inputs ?
My question is oriented about DMA and IRQ problem with 6602 and 6624 boards.
Will I be able to measure 4kHz signal with pulse width of 2.5% to 97.5% . My system will have to support upto 32 PWM inputs.
Thanks for your help .
(5,755 Views)
If you can measure this with programming language, it should have no problem using VeriStand.
(5,621 Views)
