VeriStand
Question regarding Network heartbeat
Hello
I'm really appreciated if anyone help me out whether Veristand has network heartbeat functionality on it.
[background]
I use Veristand for HIL with PXI-RT.
For safety reason, I would like to stop other mechanical and electrical facilities when communication between Windows host PC and PXI-RT Target lost for some reasons, such as Windows freeze and Network trouble.
So I would like to detect communication failure on PXI-RT, and then turn off mechanical relay.
Any advice would be greatly appreciated.
thanks regard
(2,637 Views)
From where would you actuate the facilities? and how?
Projektingenieur
Restbust, Simulations and HiL development
Custom Device Developer
(2,521 Views)
I would simply use a user a channel within your VS project called PC Watchdog and broadcast your host PC heartbeat to this using the workspace manager over the Veristand gateway
I would then have a simple watchdog "model" (I've taken to thinking of these as scripts as they are just a piece of code and dont have to be models) that outputs a boolean high when your watchdog is trippped
You could have an alarm watch this output from your watchdog model that when tripped runs a procedure that closes relays and such as desired
(2,513 Views)
I've used this watchdog method:  https://forums.ni.com/t5/NI-VeriStand/Configure-Watchdog-in-Veristand/td-p/2717405?profile.language=...
You could adapt it for your needs.
(2,502 Views)
