VeriStand
RT FIFO Read does not return default value
Hello everyone,
I am working on a RS485 Custom Device (CD) which shall be accessed via input and output channels.
I can send data to the CD, which is read with the "RT FIFO read.vi". The "Element" connector of this VI is an array initialized to 0 (please see attached image). In the event of a timeout I am expecting to get this array. Nevertheless I am getting always after a timeout the last read array. This happens for any timeout value (even 0 ms).
Am I missing here something? I need to get the standard array (initialized to 0) in the event of a timeout.
Any help is highly appreciated!
DBallen
(3,568 Views)
Accepted by topic author DBallen
Hi BBallen,
I tried to replicate this on my computer, however, I was unsuccessful with the code I've created.
As far as I understand, your main aim is to detect the underflow and in case of timeout, you would like to return previously determined value, not the last one - which is the default behaviour of RT FIFO.
Do you think you could use the below code as a workaround?
Let me know if this works for you and if you can treat it as a sufficient solution.
Mateusz
CLA,CTD,CLED
(3,472 Views)
Hi Mateusz,
your workaround works. I would expect to get this behavior from the RT FIFO vi, but your solution also provides the functionality I require.
Thank you for your help!
Diego
(3,460 Views)
