VeriStand
RT Sequences in parallel in Sync ?
This is a follow-up on this post.
I create several sequence calls on a given sequence, each with different parameters settings:
then I start them all in parallel:
Are all sequences starting in sync, or one after the other ?
Thx.
L.
(5,920 Views)
Accepted by topic author LDBM
All sequences started together in a session running on the same target will start on the same timestep. They are synchronized.
Jarrod S.
(5,901 Views)
Thx Jarrod.
L.
(5,897 Views)
