VeriStand
Reading dbc file
Can anyone guide how to load CAN .dbc file from Veristand project to access the signals on CAN messages ?
(2,832 Views)
1]  Right-Click on XNET Databases and browse to your .dbc file
2]  Right-Click on NI-XNET -> CAN and select "Add CAN Port"
3]  Confirm Interface Name, Baud Rate, etc. in CAN Port Specifications
If I misunderstood your question, and you are actually trying to look at the .dbc file to edit it or make changes, you can use Start -> Programs -> NI-XNET Database Editor.
Most .dbc files can also be opened as .txt in Excel
(2,795 Views)
