VeriStand
Reinstalling VeriStand
I have had VeriStand 2013 SP1 on my work laptop for a while now and I can't reinstall it.  I used this laptop to try to install VeriStand on another PC that was on the same network and now the NI installer will always try to remove/repair that install and not the one on my laptop.  Is there a way to specify which one I want to remove/reinstall?
e.g.
my install path "C:\Program Files 9x86)\National Instruments ........"
path installer is using "\\computers name on network\C$\Program Files 9x86)\............."
(4,698 Views)
I am a little confused on what your current set up is.  How did you use your laptop to install VeriStand on another PC?  Did you uninstall VeriStand software on your Laptop?
Can you run a repair of VeriStand on the PC or Laptop following these instructions?
M. Whitaker
ni.com/support
(4,679 Views)
