VeriStand
Required software to load a VeriStand project with operator license.
There is a PXIe-1082, which should be loaded via a control PC with a VeriStand project and with a LabVIEW application. The PC has an operator license of VeriStand.
I have set up an other PC so far, in which I have installed the LabVIEW2016 Run-Time Engine 32 and completely VeriStand2016. Thus, a VeriStand project can be deployed with a LabVIEW application via VeriStand-API.
Is there a small VeriStand operator SW package or does VeriStand have to be completely installed to be able to deploy a VeriStand project as an operator?
Developer: Winows 7 64, VeriStand 2016 Full, LabVIEW 2016 32 Full
Operator: Windwos 7 64 ... ??
(3,296 Views)
Accepted by topic author Rokot
There is only one VeriStand installer for all licenses. (Re-)using the installer you got was exactly the thing to do.
(3,154 Views)
