VeriStand
Rockwell style Industrial TCP/IP communications integration
Good morning, I am trying to integrate a Micro Motion flow meter with a 5700 w/ethernet transmitter into a couple of existing PXI chassis running veristand 2018. I am currently using a couple of custom devices to transfer data between labview running on the PC and veristand running on the PXI chassis (TCP/IP add-on, Instrument add-on, and reflective ethernet from dVel) so I have a little bit of experience doing some TCP and UDP communication in Veristand, but I have very little experience with industrial communications. The only manual I have for the flow meter's ethernet communication is this guide for integrating into Rockwell PLC's with RSLogix 5000 (https://www.emerson.com/documents/automation/integration-guide-rockwell-supplement-micro-motion-5700...). I have connected to the meter over ethernet with the PC I use to deploy the veristand projects by simply connecting with a web browser but have been completely unsuccessful getting any data from it to show up in Veristand. I tried "Ethernet Custom Device" as well which I thought looked promising but haven't been able to get anything to work in that either. I'm not sure what to put in for "backplane port" or "Logix slot". I did have someone with a licensed copy of RS studio create a small .L5K project that included the .EDS file from the flow meter but the custom device didn't import any tags from it. I did run wireshark while communicating with the transmitter using a web browser but I'm thinking it would use a different port than that (80) when communicating directly.
I'm a little lost on which direction to take on this project and would appreciate any advice you have. Thanks!
(2,345 Views)
Still working on this, guessing nobody has suggestions?
(1,346 Views)
We are currently using the Ethernet/IP custom device to communicate with A/B CompactLogix controller tags:
https://github.com/NIVeriStandAdd-Ons/Ethernet-IP-Custom-Device
(1,320 Views)
