VeriStand
Run Veristand engine on PC without any hardware
Hello All,
I am new to Veristand and want to run run a basic default example where the controller is my PC with operating system "Windows" and IP address "localhost".  However, when I try to deploy and run it is giving me an error.  I am not sure if we always need hardware target for Veristand.  Are there any getting started projects?
(1,714 Views)
There is a default Engine Demo example project. Have you tried it out?
https://tmesystems.net/
(1,691 Views)
Hello Thanks for the reply.  Yes it is giving me the same error.
(1,651 Views)
It works now.  I had to disable my network adapter and then it works. It does not work if my network is connected to the web.
(1,613 Views)
